Post Reply  Post Thread
Power Cap
Author Message
Cruiser87
Junior Member
Group: Registered
Status: Offline
Post: #1
Power Cap
Ive just purchased a power cap to put into my car.
Firstly it needs to be charged up. You have to put the +ve from the battery to one end of the bulb then a wire from the other end of the bulb to the power car to the power cap. When the bulb goes out its charged, whats the best way to do this?
To wire it up would it just be easier buying another amp wiring kit it wire it up?? I know i can use the speaker cable in the kit for other things.
Also do u just wire it up +ve from the battery to + terminal on power cap them +ve wire from the same terminal to the amp? Do you need to keep the +ve from the battery separate from the +ve wire? I.E Not letting the terminals touch.
Then just take the earth from the - terminal on the power cap to the car body?
Thanks in advance
Mk2 Seat Ibiza - Alpine White.
25-07-2007 07:40 PM
Find all posts by this user Quote this message in a reply
oBladeo
Senior Member
Group: Registered
Status: Offline
Post: #2
i run 3.5 Icon_biggrin
Spider-pig, spider-pig, does whatever a spider-pig does, can he swing, from a web, no he can't, he's a pig.
http://demp.se/y/downloads/SpiderPig.mp3
25-07-2007 07:43 PM
Newth
Super Moderator
Super Moderators
Group: Super Moderators
Status: Away
Post: #3
that diagram should clear it up. good work.
to charge it, do what u've just said. if u've not got the proper leads, u can charge a cap with jump leads & a car indicator bulb. connect the jump leads to ur car battery. now connect the earth lead to the earth terminal on the cap. Hold the bulb in the positive end of the jump leads, ie grab it with the croc clip. next, place the centre/bottom of the bulb down onto the positive terminal of the cap. ENSURE THE POSITIVE LEAD ONLY TOUCHS THE OUTSIDE OF THE BULB & NOT THE POSITIVE CAP TERMINAL! as u do this, the bulb will light up for a small amount of time. when it has totally gone out, the cap is charged. to check, put a voltmeter across the cap. when totally disconnected from anything else & it should read between 10 & 13 volts, depending on ur battery.
the easiet way to install one, is to place it very close to the amp. TAKE THE UNDER BONNET FUSE OUT FIRST. make sure the power cable running to ur amp can pass over the caps positve terminal. where it does, cut the cable through at that point. connect a ring terminal to each cut end & connect both of those to ur caps positive terminal. now run a second earth wire from where ever u have earthed the amp, to the earth terminal on the cap. job done, once the fuse it back in.
ps obladeo, how do u have 3 & a half caps? lol
Project Car Progress Bar [llllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllll]
27-07-2007 02:55 AM
olstar
Where's the rust at?
Administrators
Group: Administrators
Status: Offline
Post: #4
i was thinking that.. isnt it a bit dangerous to cut a power cap in half?
Or is only half working Icon_lol ??
Need alloy wheels?
Need modified car parts or performance car parts?
Click here -->www.Maxxdirectory.co.uk
27-07-2007 05:50 PM
Visit this user's website Find all posts by this user Quote this message in a reply
oBladeo
Senior Member
Group: Registered
Status: Offline
Post: #5
i have 2 x 1 farad and a 1.5 farad lol
27-07-2007 08:43 PM
Newth
Super Moderator
Super Moderators
Status: Away
Post: #6
lol, that makes more sence. I've only got 2 caps. Icon_sad
27-07-2007 09:36 PM
Cruiser87
Junior Member
Group: Registered
Status: Offline
Post: #7
So there isnt much point in buying another wiring kit then?? Just use what ive got??
Also are the terminals on the +ve of the power cap touch?? I.E the one from the battery to the power cap then the one from the power cap to the amp???
Also which should go on first??
Also with regarding to cutting the +ve cable i think that i will just disconnect it from the battery first to eliminate any problems!
04-08-2007 09:19 PM
Newth
Super Moderator
Super Moderators
Status: Away
Post: #8
just get a length of earth cable & a couple of rings terminals
errr, i think ur right, but not sure what ur asking. the wire comes from the battery onto the positive terminal on the cap, then from the same positive terminal on the cap to the amp
Which what?
Very wise
06-08-2007 04:42 PM
Cruiser87
Junior Member
Group: Registered
Status: Offline
Post: #9
Should the terminal ring on the wire from the battery and the terminal ring from the amp cable touch when on the +ve terminal of the power cap or should there be a spacer between each terminal ring?? Or doesnt it matter?
Should the power cable which goes to the amp go on the power cap terminal first or should the cable from the battery go on first? Or doesnt it matter??
06-08-2007 07:37 PM
Newth
Super Moderator
Super Moderators
Status: Away
Post: #10
matters not mate on the order, now i see what u mean.
yes they should be touching, try to make the electrical connection as good as u can.
suggested order to work......
1. remove fuses or main power cable from battery.
2. cut power cable & attach rings
3. charge cap
4. attach new rings to the +ive cap terminal
5. attach new earth wire to the cap -ive terminal
6. attach new earth wire to the car
7. put fuses back in etc. (don't be suprised if u get a little spark)
07-08-2007 12:20 AM
Cruiser87
Junior Member
Group: Registered
Status: Offline
Post: #11
Thats alrite then cos in the instructions it says you have to connect the amp to the power cap first and earth it then charge it.
Just thinking about it tho, doesnt it defeat the purpose of having a power cap if the wire from the battery to the power cap and the wire from the power cap to the amp are touching?
Now i know what im doing 100% now.
Thanks for the help guys.
07-08-2007 07:07 PM
Newth
Super Moderator
Super Moderators
Status: Away
Post: #12
just think of the cap as another little battery, wired in parallel. So no, it has to be touching to work.
08-08-2007 01:28 AM
  Rolling road power runs(x3 per car) £50inc Uk Dave 4 76 26-10-2008 03:28 AM
Cool team ballistic car in max power etc r5ben 7 156 20-06-2008 07:50 AM
Last Post: nez
  apexi power fc, what do i need? turbo255 7 129 22-10-2007 02:19 PM
Last Post: turbo255
  XS Power Supra European Record Holder oBladeo 12 246 16-08-2007 07:46 PM
Last Post: Roger_Sausage
  xs power intercoolers? turbo255 21 455 10-07-2007 07:10 PM
Last Post: oBladeo
  Correct amp to power subs fre3 8 136 18-05-2007 08:29 PM
Last Post: xr2i_lad
View a Printable Version
Send this Thread to a Friend
Subscribe to this Thread | Add Thread to Favorites
Rate This Thread:
