Post Reply  Post Thread
Pages (24): « First < Previous 8 9 10 11 [12] 13 14 15 16 Next > Last »
1 Votes - 5 Average   *Member* Ste's 106 Gti - Updated Engine rebuild WIP Pics 11/05/08
Author Message
widdo
Posting Freak
Group: Club Supporter
Status: Offline
Post: #166
RE: *Member* Ste's 106 Gti - Updated Engine rebuild WIP Pics 14/04/08
that looks a good car but it aint a 106 gti lol. if i had the spare money then yes i would TB it. but on every gti iv seen, it doesnt seem to be worth the money. just my opinion!!!
Pug 106 GTI --1/4 mile --- 14.52 @ 94.68mph
"iz day space savers mate innit?"
Screech for MOD.
www.maxxd-motorsport.com
17-04-2008 12:49 AM
Visit this user's website Find all posts by this user Quote this message in a reply
d_diddy
TEAM DAVE
Status: Offline
Post: #167
i suppose its down to the original engine and what its like with an ITB conversation.
17-04-2008 12:51 AM
ste
Administrator
Group: Administrators
Status: Offline
Post: #168
Every one i've spoke to and most of 106owners want to go TB's
That many people cannot be wrong about them and the benifits of having them
The kit I am going for is :
Jenvey 42mm ITB's
Fully programmable Omex ecu and loom
Omex fuel pressure reg
Mapping software + base map
ant Wrote:
" pistons fisting like a nazi, drive my car like kamakazi. More skill than kill bill, one two, john woo, kung-fu,eat my poo, subaru!"
17-04-2008 01:02 AM
d_diddy
TEAM DAVE
Status: Offline
Post: #169
make sure the omex is at least the 600 series if not higher.
17-04-2008 01:07 AM
ste
Administrator
Status: Offline
Post: #170
I'm pretty certain it is
17-04-2008 01:16 AM
nez
Senior Member
Group: Club Member
Status: Offline
Post: #171
awsome cant wait for this
Nez`s WRX 1/4 mile :
13.87 seconds @ 98.4 mph
249.3 BHP @ 6816 RPM @ 11PSI
17-04-2008 07:58 AM
ste
Administrator
Status: Offline
Post: #172
Right then...
Today is the day.
I have just placed the order for :
Semi-sequential fuel injection for up to 4 cylinder engines
Distributorless or distributor ignition for up to 4 cylinders
Programmable load and speed sites
TPS or MAP can be used for main load sensing
Wide range of crank trigger patterns are suitable (user programmable)
Turbo wastegate control
Turbo anti-lag system
Variable cam control
Traction control (Software upgrade coming soon)
Narrow and wide band lambda support
Push/pull, and single line idle controls in addition to scattered spark control
Knock sensing capability
3 programmable outputs switched on user controlled inputs (eg boost, coolant temp etc)
Security protected calibrations
Full throttle gearchange
Intercooler water spray control
Water injection control
Nitrous ignition retard and fuel enrichment
Two cooling fan controls
Barometric compensation with external sensor
Uses the latest version of the superb MAP2000 Windows programming software
Suitable for normally aspirated or boosted engines
Inbuilt independent fuel and ignition rev limiters
Separate Tachometer, Shift Light and Fuel Pump outputs
Magnetic or Hall Effect crank and cam sensors
Automatic interpolation between mapped sites
Sophisticated acceleration fuelling setup
Various harness options from economical semi-assembled to full race quality bespoke looms
Battery voltage compensation table for fuel injectors (not just a simple number)
Battery compensation and engine speed compensation for coil charge time
Mappable coolant temperature compensation for engine warm-up
Air & coolant temperature compensation for fuel injection pulse width
Separate cold cranking and decay tables in addition to warm-up fuelling
User settable ignition trim based on air temperature, coolant temperature, and barometric pressure
Separate start advance for cranking provides easy starting for high compression engines
Deceleration fuel cut-off feature for road engines
Maximum recommended engine speed 12,750 RPM
one of these
Omex Rev Limiter With Launch Control Facility
Microprocessor controlled, Accurate digital setup, Hard/Soft cut option, Suitable for 2/4/6 or 8 cylinder
Usefull for all engines which have had their rev limiters removed for whatever reason, such as fitting carburetors.
Supplied with all fitting/setup instructions and also launch control button.
A set of these beauties:
Wiring loom
Programming software
Base map
17-04-2008 11:00 AM
hj1298
*Mrs M1ke*
Status: Offline
Post: #173
oh it will be great.... cant wait to see this once it is done...
36 days ste Icon_wink
Ann Summers rep - pm me for details
Drive like a cunt... get treated like a cunt!
15.2974 1/4mile @92.47
Order your Maxxd.com Keyrings through Hj1298 and M1ke - £2 each
17-04-2008 11:10 AM
ste
Administrator
Status: Offline
Post: #174
Yeah thanks
It's actually 35 for me. I'm helpin newth with his galaxy on saturday.
17-04-2008 11:16 AM
Roger_Sausage
Ban Me!
Status: Offline
Post: #175
I take it air filters are out of the window then!? Icon_lol Don't get a lot of room in there do you, have you got to chop anything away?
*insert witty remark here*
rogersausage.wordpress.com
17-04-2008 11:18 AM
Stacy
106 Widow
Group: Club Member
Status: Offline
Post: #176
It doesn't look very pretty, you best make ours look nicer
17-04-2008 11:27 AM
ste
Administrator
Status: Offline
Post: #177
yeah i guess, you can get them to cover the trumpet totally.
should go straight in without chopping anything about. ppl do chop the panel directly behind to allow extra airflow, but that is "optional"
17-04-2008 11:28 AM
olstar
Where's the rust at?
Status: Offline
Post: #178
I have a tin of beans you can have Icon_smile
seriously tho, looks mint Icon_smile
Need alloy wheels?
Need modified car parts or performance car parts?
Click here -->www.Maxxdirectory.co.uk
17-04-2008 11:57 AM
widdo
Posting Freak
Status: Offline
Post: #179
bloody hell how much all that kit costing? lol. wish i had the money!!
Screech for MOD.
17-04-2008 05:14 PM
ste
Administrator
Status: Offline
Post: #180
Enough... Icon_wink
17-04-2008 05:16 PM
  *member* ASH's mk2 polo updated 5/6/08 ASH 28 337 08-06-2008 01:27 AM
Last Post: ASH
  *Member* Yoda13a - The lastest rebuild. Newth 48 627 01-05-2008 10:03 PM
Last Post: a_coates
Toungue UPDATED Project CRX Pics jakethesnake180 4 131 01-05-2008 01:58 PM
Last Post: ste
View a Printable Version
Send this Thread to a Friend
Subscribe to this Thread | Add Thread to Favorites
Rate This Thread:
