Engine Trouble
| Author |
Message |
spage
Senior Member
Group: Club Member
Status:
Offline
Engine Trouble
My car doesn't seem to be cooling when stood at lights etc and i can't hear the fan kicking in either, the car seems to be running abit hotter than normal.
What could be causing this and what can i do to sort it out?
[SIGPIC] [/SIGPIC]
| 24-07-2007 02:50 PM |
Newth
Super Moderator
Group: Super Moderators
Status:
Away
if the fans not kicking in, get it tested. normally points to the fuse, switch on the engine block or the fan itself.
10 minutes work with a multimeter, normally.
Project Car Progress Bar [llllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllll]
| 24-07-2007 03:02 PM |
spage
Senior Member
Group: Club Member
Status:
Offline
To be honest i havn't got a clue what im doing with it, can you explain in simpleton terms?
[SIGPIC] [/SIGPIC]
| 24-07-2007 03:06 PM |
Newth
Super Moderator
Status:
Away
my advice, if u know nothing about it, seek someone to have a look at it.
but......
u need to measure the voltage across the fan & switch, to ensure thats there to start with.
by-pass the switch to make sure it's not that
directly wire the fan to 12volts to test that.
| 24-07-2007 03:15 PM |
spage
Senior Member
Group: Club Member
Status:
Offline
Do you know anyone who can have a look at it for me?
[SIGPIC] [/SIGPIC]
| 24-07-2007 03:16 PM |
Newth
Super Moderator
Status:
Away
not really my thing & i'd be taking the piss if i told u i had time.
someone will offer to help i'm sure, i'm not gonna offer on their behalf. lol
| 24-07-2007 03:23 PM |
dan_sri
Senior Member
Group: Registered
Status:
Offline
best thing to do is park it up with the engine running and once it gets to the "normal temp" (usually about half way) the fan should kick in.... but DONT let it run too hot!
it could be that the weather changing has caused it to run a little hotter, try dropping the water and puttin some fresh water and anti-freeze/coolant in.
www.modifiedsparx.com - Dan@modifiedsparx.com
| 24-07-2007 04:32 PM |
oBladeo
Senior Member
Group: Registered
Status:
Offline
Could be the water pump
can't be arsed to read the thread lol
Spider-pig, spider-pig, does whatever a spider-pig does, can he swing, from a web, no he can't, he's a pig.
http://demp.se/y/downloads/SpiderPig.mp3
| 24-07-2007 06:47 PM |
dan_sri
Senior Member
Group: Registered
Status:
Offline
could be a number of things realy, thermostat, water pump, temp sensor, fan relay/fuse..... brutons ya best bet mate.....
| 24-07-2007 06:52 PM |
OllieWestwood
Super Moderator
Status:
Offline
1. Top 100 Show Car 2. 13 sec 250+bhp RWD monster 3. Daily runabout well detailed 4. New Toy..The Track Car - but i know fuck all about this scene........
Understeer: when you hit the wall with the front of the car.
Oversteer: when you hit the wall with the back of the car.
Horsepower: how fast you hit the wall.
Torque: how far you take the wall with you.
***Nissan 200SX S14a 203.2bhp 194.6lbft - 13.89@100.60***
| 24-07-2007 06:55 PM |
spage
Senior Member
Group: Club Member
Status:
Offline
Yes the heaters are blowing hot, i've topped the coolant up already and that asn't made any difference. I've also let the engine run twice now and when it gets to the normal temp the fan doesn't kick in.
[SIGPIC] [/SIGPIC]
| 24-07-2007 07:07 PM |
OllieWestwood
Super Moderator
Status:
Offline
sounds like a dodgy connection or fuse
Look on the fuse panel and it should have a list of what is what find the fan fuse and check it then come back to us.
| 24-07-2007 07:23 PM |
spage
Senior Member
Group: Club Member
Status:
Offline
I've opened the fuse box and looked at the lid and there is just numbers it doesn't tell me what is what.
[SIGPIC] [/SIGPIC]
| 24-07-2007 07:27 PM |
Spener
Senior Member
Group: Registered
Status:
Offline
It will do in your manual
Hitler the Dubber
M.I.V.W Roadtrip 2009
Like Les Ferdinand famously said after a match against Leyton Orient after a LDV cup match in 1996 "if it wasnt for the Vag motor group id kill myself because there cooler than dino-riders and the A team put together" true story...
| 24-07-2007 07:29 PM |
Spener
Senior Member
Group: Registered
Status:
Offline
Try number 52, should be a 30amp
Hitler the Dubber
| 24-07-2007 07:33 PM |
