Black Smoke Problem,help! HILUX SURF,
18-07-2007, 11:13 PM
Post: #1
I HAVE A 2.4TD HILUX SURF I USE AS MY EVERY DAY TOOL,ONE PROBLEM ITS BLACK SMOKING UNDER ACCELERATION,WONT BE LONG BEFORE I GET PULLED IF I DONT GET IT SORTED! APART FROM THIS IT RUNS AND DRIVES LIKE NEW, I KNOW THESE ARE KNOWN FOR SMOKING AND THERES LOTS OF PEOPLE ON EBAY SELLING CURES FOR THIS LIKE EGR BLANKING PLATES ETC! BUT IVE ALSO HEARD THESE ITEMS DO THE ENGINE NO GOOD! HELP AS I WANT TO SORT IT BUT I ALSO DONT WANT TO FUCK IT UP BY DOING THE WRONG THING.:confused:
BIG,BOLD,RUFF AND READY,SEXY AS HELL! |
18-07-2007, 11:16 PM
Post: #2
i think you will find that under hard acceleration most Diesels smoke black, or works focus do and there brand new.
Unless it is thick and reduces visablility to road users behind you and/or does it all the time even on idle..id ignore it! 1. Top 100 Show Car 2. 13 sec 250+bhp RWD monster 3. Daily runabout well detailed 4. New Toy..The Track Car - but i know fuck all about this scene........ Understeer: when you hit the wall with the front of the car. Oversteer: when you hit the wall with the back of the car. Horsepower: how fast you hit the wall. Torque: how far you take the wall with you. ***Nissan 200SX S14a 203.2bhp 194.6lbft - 13.89@100.60***
18-07-2007, 11:22 PM
Post: #3
OllieWestwood;21113 Wrote:i think you will find that under hard acceleration most Diesels smoke black, or works focus do and there brand new. ITS FINE WHEN TICKING OVER OR JUST CRUISING,ONLY ON ACCELERATION IT BLACK SMOKES LIKE A CHIMNEY! BIG,BOLD,RUFF AND READY,SEXY AS HELL! |
18-07-2007, 11:39 PM
Post: #4
![]() Just in case you didn't know how to turn caps off
19-07-2007, 08:59 AM
Post: #5
ste;21119 Wrote: key boards fucked,caps comes on and of as it pleases must go get a new one just not had time! BIG,BOLD,RUFF AND READY,SEXY AS HELL! |
19-07-2007, 12:13 PM
Post: #6
Have you tried changing the fuel filter as that can be a main cause for more than normal black smoke from a denzel
Dont play away when your mates around, because you might need a tow while your with ya hoe |
20-07-2007, 08:39 AM
Post: #7
StiloJoe;21175 Wrote:Have you tried changing the fuel filter as that can be a main cause for more than normal black smoke from a denzel did have a service just over 2 months ago but im going to give it another full service over the weekend as it does get used a lot and clocks up some millage! BIG,BOLD,RUFF AND READY,SEXY AS HELL! |
20-07-2007, 11:54 AM
Post: #8
Have the seals gone on the turbo and it's throwing oil into the exhaust maybe?
Not sure how black the smoke is that he's talking about tho as oil burning is more white Spider-pig, spider-pig, does whatever a spider-pig does, can he swing, from a web, no he can't, he's a pig. http://demp.se/y/downloads/SpiderPig.mp3 |
20-07-2007, 11:56 AM
Post: #9
Black smoke will be fuel and carbon, oil would be blue and white. Good thinkin' tho.
Sounds like it just needs a good scrub out, but I wouldn't. Because if you decoke the motor and there's carbon in there that's filled any small block cracks then you could do more harm than good. Stick some Redex diesel through it and adjust the fuelling to drop a little less fuel in. Make sure it's not too much tho, else you'll need to change your boost too. Piman2k.com Vehicle Photo Galleries |
20-07-2007, 06:52 PM
Post: #10
most common black smoking faults on them are either EGR valve sticking, or more commonly fuel pump will be ready for overhaul as there a tiny spring inside that normally breaks causing them to over fuel under acceleration.
www.maxxd-motorsport.com |
« Next Oldest | Next Newest »
| Possibly Related Threads... | |||||
| Thread: | Author | Replies: | Views: | Last Post | |
| sub/amp problem | crew-C2EWX | 11 | 123 |
02-08-2008 01:04 PM Last Post: crew-C2EWX |
| Sub/Amp wiring problem????? | jamieaston1 | 2 | 48 |
01-08-2008 11:06 PM Last Post: Bruton |
| Serious Sub/Amp wiring problem | jamieaston1 | 5 | 90 |
25-07-2008 11:04 PM Last Post: Ant |
| Serious Wiring problem | jamieaston1 | 6 | 90 |
25-07-2008 10:06 PM Last Post: jamieaston1 |
| Mitsubishi Colt problem | Colt_Liam | 5 | 172 |
11-02-2008 08:19 PM Last Post: Colt_Liam |
| punto problem | pops | 25 | 462 |
24-10-2007 11:05 PM Last Post: pops |
| Steering problem | spage | 9 | 154 |
22-10-2007 07:03 PM Last Post: nez |
| HELP! hilux surf electric rear window not working, | slysicars | 4 | 85 |
10-09-2007 09:55 PM Last Post: slysicars |
| problem with the rear windscreen | xXxrachxXx | 1 | 93 |
14-07-2007 05:21 PM Last Post: Reef |
| turbo problem | widdo | 9 | 229 |
14-07-2007 02:36 AM Last Post: widdo |
Homepage
Gallery
Videos
Search
Member List
Calendar
Help
![[Image: caps_2Dlock.jpg]](http://www.gottabemobile.com/blogimages/caps_2Dlock.jpg)
